Hey guys...
Recently upgraded to a Koni 8611 (front and rear) and ground control setup...my old(er) Tein HE's served me well, but it was time to upgrade.
With the old setup, the car was VERY neutral, and very predictable. Slight hint of oversteer, but just a great level of grip (on smooth surfaces, at least).
With the new setup, it's "twitchy", I'd say. Too tail happy. I've done one autocross (just to test it out), and one open track event (small track, Gainesville Raceway)...and I'd say the car exhibited the same behavior at both (especially before making changes).
Pertinent details:
OLD: Tein HE's, 448lbs/in(F), 336lbs/in(R). Whiteline front anti-roll bar, stock S14-SE rear anti-roll bar.
NEW: Koni 8611's (F&R), 500lbs/in(F), 350lbs/in(R). Whiteline front anti-roll bar, stock S14-SE rear anti-roll bar.
Identical ride height and alignment.
Same wheels/tires (255/40-17 Kumho XS's, on 17x9, +18 RPF1's).
S14, weighs a little less than 2700...KA-T making ~320rwhp.
Notice that I went up in spring rate significantly more up front, as compared to the rear.
SO...
What I've tried:
Remove rear anti-roll bar...no significant change. That leads me to believe it's all shock setting related.
I have added 2 clicks of compression damping in the front (making it 7 clicks off of full soft), and dialed out almost all of the rebound (it was almost full stiff, F&R...with respect to rebound...when I installed the shocks). Koni install sheet has you start there...that's why I made that change.
That netted a positive change, but has not cured the issue.
One thing I have not touched - Rear compression damping. I have no idea where it's set, as the rear housings modified do not allow a quick and easy way to access the adjuster. They do work with stock S14 rear knuckles, however
SO - Baseline settings, or input would be great.
Thanks...
- Brian
Pertinent details:
SO...
What I've tried:
Thanks...
- Brian
