So this might not be the proper term, but I'm looking for some help in fixing a timing issue. I spoke with a local tuner last week, and this is what he described, so I figured I'd roll with the term, and try to get this thing fixed.
Anyone who's been following my build thread will know that I've had a number of engine troubles over the past year or two. I'm starting again with a fresh engine, and want to finally get this thing running properly.
My tuner described an issue that he's seen with the AEM EMS that's caused by the apparent low resolution of the software, not being able to keep up with the SR20DET igniter/ CAS count. The issue that he's seen is best described as timing staying solid until you get higher in the rpm range, then the software can't keep up and timing basically goes out the window, jumping around everywhere.
My issue is not the same as this, what I've seen is a little more manageable. I can set my timing to 15deg at idle, and it's fine. Once I hit 1500ish RPM my timing jumps up into the 25ish (I'm guessing) range or more! This is with all of my tables set to 15 deg across the entire map.
I am able to set timing at idle to a jumpy 6-8deg somewhere, and when I rev the engine past 1500rpm and into the 6000rpm range (standing still) the timing sits solid at 15deg.
So basically it looks like I'm gaining 7-8 deg or more when moving from idle to operating range using this one test. Does anyone have any suggestions or any info about my problem? I don't think it's an AEM issue, as I can get the timing to stay at 15deg through higher rpm, I just have the issue of setting my timing at idle now??? Timing is measured with a plug wire between coil #1 and plug #1, with an adjustable timing light set at ZERO degrees. Crank pulley is reading 15deg with tables at 15deg.
