So kind of a shot in the dark here, but as I start digging into my wiring issues, I figured that I'd post up and get any advice/tips from you guys that have faced these problems before.
1) Brake lights not working.
- 10A fuse is blown, and it blew another spare as soon as it saw power.
- I had removed the ABS wiring and control unit from the rear end of the car last year, but didn't touch the main rear harness.
- Rear running lights and turn signals work fine.
2) Reverse lights not working
- Reverse plug in transmission is plugged in, no promises on condition of the plug itself and the associated wiring
- Thinking it might be the same issue as the brakes, as they are both on the same harness
3) Horn not working
- My horn has always been on/off, mostly because of a crappy connection at the hub (spring not making contact with the metal contact ring), however I pulled the spring into position with the wheel off, and it still doesn't work
- Not sure what to think here, I guess I'll start in the FSM for each problem and begin chasing wires.
Any help with these issues would be great, as I'm going back to work on Tuesday, and I'm trying to get to AutoX in the morning, AND an out of province inspection on Monday!
Thanks guys.
3) Horn not working
Thanks guys.
