fuel level sender issue.
  • fuel level sender issue.
    Short story is going to be short, at the end of my first session on NT-01's, the fuel level was showing empty :P.
    At first, I was scared I had a leak pissing everywhere on the track or my engine bay.
    Has anyone had his fuel sender break because of lateral forces?
    I haven't verified yet, but just wanted to know if someone had this happen to him :P.
    Update : Fixed! Baffle plate was loose. Winner: HybridAndy ! lol
    Mine is broken, but I think it's the cluster and not the sender, or the wiring in between. Well, it works for the first 1/4 tank or so, then goes wonky. It will drop to 1/4, then back up to 1/2 and generally not give any sort of accurate reading.
    I replaced the sender once already and it does the same thing, which is why I suspect the cluster instead.
      My sender works fine. I'm using a VDO fuel gauge which seems to match up really well to the stock sender (fills up to like 95% on the gauge when full, and I've gone to maybe 1/16th of a tank showing on the gauge and filling up with about 12.6 gallons. It's the VW 10-65 ohm one IIRC.
      Pretty sure this is it:
      Free Shipping - VDO Cockpit Series Analog Gauges with qualifying orders of $99. Shop Gauges at Summit Racing.
        my s14 fuel sender has slipped off of its bracket twice during autocross to swim around, keeping the gauge needle pegged at Full. After the 2nd time, I zip tied it to the bracket. No problem since then.
          This is pretty much how mine works. Seems fine till half a tank and then goes from 1/2 a tank to a 1/8 a tank a couple times back and fourth. Pretty much unreliable after a half a tank.
          It also fuel starves on road course so I try to keep it above 3/8ths a tank If I can figure out when that actually is.
            All I can say at least it wasn't a leak and my car didn't catch fire.... I was freaking out at first.
            So its either the floater from the sensor slipped off, or my gage on the dash stopped working .
            I really don't care much, but since its now my daily + track its going to be hard to keep track of my fuel level.
            I should be checking it out in the next days...I will update then.
              First time I took my S13 to an autox on my RT-615 I had the same thing happen. Turns out some of the metal baffling in the tank itself came loose and was pinning the float to the bottom of the tank.
              I opened the tank from the top and and bent/wedged the loose metal back down and it's worked fine ever since.
              Make sure you pickup a new o-ring for the access panel to the tank before you open it. I had just opened mine to install a new fuel pump a few months before the o-ring had already expanded enough that I had to replace it again.
                I have to find a standard part for that. It has been already 3! stupid o-rings. And its expensive at 15$ a piece.
                I happen to have one new. Took some rough mesuring tape measurements
                circumference :405mm
                Od= 128.9 aprox 128 mm
                W=4mm
                Found something, much cheaper http://www.mcmaster.com/#o-rings/=c6e4f9
                  My local advanced auto has them for about $10 a piece. Looks like McMaster has a pack of 10 for about the same price.
                  They didn't have one in stock the last time I fixed mine so I ended up cutting the o-ring and sealing the gap with RTV until the new one came in. I have the new ring but haven't installed it yet. The seal seems to be holding up alright so far but I'll probably replace it this spring when I get some time to work on the car.
                    I'm the master at re-installing those O-rings, never had to get a new one, done countless fuel pumps, it takes a little rolling motion in a small circle and a twist and it rolls back into place everytime.
                    and since some idiot will ask, NO LEAKS
                      Does it leak?
                        Does it leak?
                        I absolutely LOVE YOU
                          I've had good luck twice cutting and taping, but I usually just replace. $11 gasket from the dealer and they've always had it in stock.
                          I'm intrigued by this 'roll the gasket around in a circle and reuse it" method though.
                            Explain? you mean make it longer?
                            Actualy I have some old conveyor O-rings. I might cut out a piece and try. You can merge them by just heating the edges and letting them dry touching.
