I'm thinking of snagging an SR trans for "mad-cheap" this weekend. I'm wondering if there's anything I need to look out for that would make this more complicated than I think it is.
What I hear is that you're set as long as you swap bell housings. If that's the case, awesome.
But I wonder about the sensors on the trans being the same type / plugs? 5th gear and speed sensors come to mind?
And if I keep the KA's bell housing, my KA's clutch and flywheel will work without issue?
Spline counts and output shaft lengths all good?
