I have a 93 S13 coupe thats been sitting for just over a year now. When I turn the ignition on, everything works like it should, but when I turn it off and take the key out...not so much. The brake warning light on the dash stays on until you either disconnect the battery or you pull the fuse 2nd from the bottom on the left hand side fuse box in the car. I can't figure it out and it really needs to be fixed.
Now having said that, since its been sitting, I have removed some things. I put a LS1 in it so most of the factory wiring for the KA has been removed. The entire engine harness upper and lower are gone. Only 3 wires are still used on the large grey plug by the battery (constant and switched power as well as a ground) and the small orange plug next to it is not used at all. Did I possibly remove something I shouldn't have or what. I'm almost at a loss now so please help if you can. Thank you
