Let's discuss roll cages/roll bars/tension sets/chassis bracing, but in an organized fashion.
1. List make and model of your car.
2. Tell us what type of cage, or bracing you have, or what you plan to have in your vehicle. (For example: Do Luck tension set, or 6 point cage with nascar bars, welded in, mild steel, blah, blah, blah.... )
3. Tell us why you are choosing, or have chosen to install a particular type of cage/roll bar/brace. (For example: to meet tech for a specific class, chassis stiffening, safety, protection, etc.)
4. Describe any departure from the "standard", and why, and if it still passes tech inspections.
5. If you can, provide pictures of your cage/roll bar/bracing, or the cage/roll bar/bracing you plan to install.
Hopefully, this thread can be used to educate those searching for real world information on roll cages, roll bars, and chassis bracing to help them make educated choices in their own build.
