New here, and just started tracking my s13 (drift only before). it's a 180sx from japan and is fun, but i was having the worst front wheel lock up...
the car, i believe, originally came with abs but doesn't have it now and has a non-abs master. it's a 1" with the 2 front lines and one rear.
the rear brakes i believe are stock s14 brakes (it has the 5-lug conversion), and the fronts are nissan, but bigger than z32's.
I played with the idea of different master cylinders, but that would be an involved and expensive and unpredictable fiasco.
So I plumbed in two proportioning valves from summit racing.
I took it out and I ended up having to fully close the valves and still have a little premature front wheel lock up.
Which means that i am blocking about 57% of the braking to each front wheel and it's still a bit grabby up front.
I have hp+ pads up front and probably stock in rear (unsure), so maybe that has something to do with it, but it was a whole lot more fun on the track with bnrakes that actually work.
and the nice thing is i can dial them back for drifting.
