I just did this with tower240 friday/sat. if you have access to an air chizzle and a large dull flat blade for it we didnt even need the dry ice. just turn the air pressure down so you dont chizzle thru the metal....and put in earplugs. the air chizzle made quick work of major areas
That answered a lot of my questions...I've always done it the heat gun way....Loosen it with heat scrape it grind down the residue, MEK it and paint it....PITA...Looking to do dry ice for the rest of my car...any idea on price and quantity needed? I found a local distributor but no prices listed and haven't callled them yet. Any special handling instuctions? Thanks.
check your local grocery stores or outdoor supply stores. here in CA it was $1.50/lb, and we pickedup 12lbs so we could spread it around. you MUST wear gloves when touching it, it will burn you super fast..... leather gardening gloves or welding gloves is what we used
You can break the dry ice into chunks and throw it in a large ziplock bag. Place it on the areas that you want to lift. Leave it on for a few minutes. You should hear the metal start to pop. That usually means the area is cold enough. Just hit it with a rubber mallet, and it will shatter.
Tristan Smith
T-Rex Racing
SCCA ITR 300zx #56
Former SCCA ITA 240sx #56
IMSA RS 1978 Datsun 200sx #58
Better yet is when you can get a putty knife under the corner and pry up a square foot of it at a time. much less cleanup mess.
that's why I love the dry ice method.
the hardest part is getting the sloped rear parcel shelf stuff. I tried to do that in the summer and just couldn't get it cold enough. I put styrofoam behind it for insulation and covered the dry ice with 2-3" of towels trying to keep the heat off, but I never could get it cold enough to freeze. finally I broke down and air-chiseled it off and did the MEK + wire wheel + elbow grease + etc etc etc man I hate doing it that way!
Put dry ice on sound deadening. Let it sit for a few minutes, hit with a rubber mallet. Clean up mess.
I find it easier to just use a putty knife....
and use liquid nitrogen instead of dry ice. So much easier though dry ice > nothing at all.
You will need at least 20lbs to do the car if you're fast and develop a nice way to pile it up around the tunnel..... or you can just dump liquid nitro and be done with it.
