Most recent alignment:
+8deg caster (tein tension rods almost maxxed out)
-3deg camber front
-2deg camber rear
.10 toe in all around
Using j30 rear uprights for ghetto 5lug and j30 rlca's (for the correct balljoint) modded to fit s13.
All other arms are stock, although I have rear adjustable toe/traction/camber arms ready to be installed...
Now the questions:
How do you guys adjust the camber via front plates? We were loosening the hex head bolts and then wailing on the coilover nut with a rubber hammer to push it outwards.... Should I have lifted the car off that corner, adjusted camber plates, then lowered?
Also, I wanted more like -2.5deg camber in the front but the right front went all the way out and I was at -3deg. The left front was nowhere as far out on the camber plate when it got to -3deg camber.
Perhaps something is bent? Or maybe the slop in the lower coilover mount ears is responsible? I have ingalls eccentric bolts I can throw on there also.
In the rear, the most I could push out was to -2deg camber via the stock eccentric bolts.
I guess I should have tried the j30 camber arms, but I already have some Megan adjustable ones I can throw on instead.
Pics:
-3deg camber front
-2deg camber rear
Now the questions:
Pics:
