Which bushings would you Prefer, as if a Spherical wasn't an option.
Would you rather use OME/Nismo Type Rubber Bushings that have some kind of "Spring" to it?
Or would you rather use Poly Type bushings that has a lot of Friction and likes to Bind?
I do believe for the FLCA, OEM Type is rec. to allow Axial movement am I correct? As the Poly bushings being stiff and having pretty much no play causing Binding due to Caster correct?
So pretty much what I'm asking is what type of bushing would you prefer in the proper locations?
And yes I've searched but got ALOT of controversy between the OEM Type and Poly bushings but nothing was really settled as to what using would be best in what App/Position. And I know Spherical's are pretty much the best solution we have but I'm looking into running STS Calss so I'm only allowed Rubber & Poly.
- Tension Rod - ?
- FLCA - OEM Type?
- RLCA - Poly as they only need Radial Movement correct?
- Upright - ?
- Rear Arm Links (RUCA, Toe & Traction) -
- Rear Sub-Frame - Poly to reduce Sub-Frame movement?
- Diff - Poly ^ Same?
