So after 25 dollars and a couple of hours of fabricating I finished my strut bar Ideally I wanted the front strut bar without any bends but it was not possible unless I dropped the motor or lifted the hood with washers, did not want to do any of that. I know it's best to have a straight bar across the towers, but in my case it was not possible... The bars going to the firewall are straight attached to a 1/8 plate which bolts on to another 1/8 plate behind the firewall.. The plates for the shock are also 1/8 thick. I made them from scratch, I rounded them off to give a nicer appearance... I just need to weld a master cylinder brace. But any inputs what you guys might think about the bar?
