Tell me what's available in the Nissan catalog that I can use to stop killing rear wheel bearings.
So far the count is up to:
-2 OEM Z32 NA unknown mileage (ok, used parts fail, no big deal)
-2 aftermarket Timkens from Rockauto
-1 OEM Brand spanking new S13 rear bearing from Nissan
I was hoping to eliminate the chance of counterfeit Chinese bearings I hear are invading the bearing marketplace by dealing directly with Nissan, but now I'm not so sure it isn't a systemic issue with my car/installation.
The only thing I can remotely think is that the torque isn't exact on the axle nut. My torque wrench only goes to 150 ft-lbs, so I went till it clicked then gave it another ~1/16-1/10 turn. Spec is 152-203 ft-lbs per S13 FSM. I figure I'm somewhere in the middle.
The last OEM bearing only lasted 2-4 track days. I think it died sometime on the second day of TWS, as I noticed I was getting pad knockback, but couldn't localize the source (I kept thinking front wheels). Turns out it was the driver's side rear corner deflecting on the really fast/cambered T7 as I was full on power in 4th gear and probably pulling well over 1G lateral there. It would also explain why the car was a little "odd feeling" in T6 and T2 (both higher speed right handers).
Are Z32 TT bearings stronger? I know you can't use a Z32 NA hub on them, but hell, at this point I'll get Mike to machine me up a custom hub to use my axles (cue the buttraping machine shop prices for 1 part!!!
). I don't care how crazy the ideas are, it's obvious the car is NOT happy with OEM sized bearings, so I need to do something. These things are not cheap, and I'm frankly a bit sick of replacing them.
Anyway, going to track this weekend. I think it'll be fine, as it held together before. It's not like there's anything to really hit at MSR-C 1.7 anyways (mostly).
