I'm new here and I'm glad to finally find a group that knows what they are talking about. I'm still learning, but there are something things that I've been reading that I've been getting confused about.
I was first thinking about getting the SPL Parts KTS Coilovers. Then I started reading about the Ground Control/Koni setup. From what I've been reading, it seems like I want the GC/Koni setup.
I've just started working on my car, but it is going to be used as a track/auto-x car. I've got all adjustable arms in the rear besides the lower control arm and same in the front, beside the lower control arm. The rear also has Z32 knuckles
What do I need to make the whole set up work? I want to be comparable to a coilover set up.
I've been reading all these different threads on here, and some people are using GC camber plates (which I can't find on their website), tein camber plates, & techno toys plates with different success rates. Also, some people on this forum are using Koni coilover sleeves but I can't find those either. What spring rates should I use? some people where using 440front/400rear somewhere using 500front, and even 550 front, but I couldn't find anything about their rears. I was also planning on using tanabe sway bars, but I don't know if using bars that thick with spring rates really high would be a great idea.
You help on this would be much appreciated.
