I thought I'd post a few fabrication photos from the past week. I've been working on the front end, and am confident about the way it is working out now. Its far from completion but will hold the intercooler, oil cooler and most importantly, house the four mounting points for the cage that holds the front half of the front undertray.
240rs maxi updates
Bill, nice to see you on here. I'm working on getting your setup figured out right now. I'll shoot you an email later with the details.
Tim
JESUS CHRIST! Beautiful stuff! I need a tow vehicle and trailer so I can build one like that, although probably not THAT good. You have given me soooooooo many ideas as to how I am going to build my next 240 between this thread and the ones you have on zilvia.function > form
I think I remember reading somewhere, your zilvia thread maybe, that thats a NASCAR clutch right?
sways look awesome
any idea how soon youll be running events? I hope youll be at VIR again, but Im assuming you will be'06 wrx - DD
'89 s13 hatch - jackstand racing national champion
It doesn't look like you are going to make those sway bars adjustable from the cockpit! Why not, it would be easy to do at this point? Weld a lever on the sway bar, run a cable up to an adjustment mechanism in the cockpit, done!function > form
Ahmed,
If I had any extra time I would. I can barely find a hour here and there to work on the car
Nismofly,
I will definitely be at VIR this year for GT Live. I think that will probably be the only proper event I will do. I want to do 2-3 4 hour test sessions before that and get the suspension set up and get used to driving the car with an actual differential!
Originally posted by racepar1 View PostIt doesn't look like you are going to make those sway bars adjustable from the cockpit! Why not, it would be easy to do at this point? Weld a lever on the sway bar, run a cable up to an adjustment mechanism in the cockpit, done!
I'd really like cockpit adjustable ones but that can be a winter project. I figure it would take at least 10 more hours to set that up without buying new parts from genesis or another expensive manufacturer.
I want to do very little over the winter and save money to do some bigger events
from what Ive seen you do most of your test and tune at NHIS, but if youre ever over at the glen Ill try to make it out for sure'06 wrx - DD
