Maybe a dumb question but I picked up a set of D-Max "Drift Spec" coilovers a while ago and now that I am getting closer to getting my car complete I was wondering if these will suffice for grip driving? I mean I know they are a low end coilover but what other than the spring rate classifies them as a drift coilover? They are 32 way adjustable so I figured I could get a few different spring rates adn they could work? Or would I be better off selling them and getting something closer to a K&W or Koni setup?
Differences from a drift spec coilover vs anything else?
I imagine they just charged more for putting a new sticker on the coilovers. I highly doubt they are changing the valving when they vary 100% from corner to corner on the average cheap set.
I'd sell them and piece together a Koni setup. With a little searching you can get a full set of Koni yellows and coilover sleeves for less than $800 or so.'18 Chevrolet Volt - Electric fun hatch for DD duty!
as far as i know, "drift" coilovers use much more compression than grip stuff. easier to break grip, smoother transitions, able to go lower without bottimg out, etc.
i know when i lower compression on my rears i get better rear grip in slaloms but drifting gets ****tier (more snappy)Originally posted by Jason MI have no chance to win without the Giken...
That's probably would they SHOULD do - but whether a "distributor" like D-Max does anything is very very unlikely. There's a reason they use threaded coilover bodies - it's like the same valving for pretty much every damper they put out there.'18 Chevrolet Volt - Electric fun hatch for DD duty!
HAHAHA I was gonna come in here and say "I imagine they put a different sticker or chose a different color to begin with and finish with" then I saw def posted lol"hexa-dodecahedron-triple-threaded-super-eleventy-way-adjustment-spec" dampers. -Def
