I have a question about them.
Obviously for the S-chassis, as I posted the question in here.
I have a set of HKS pillowballs that I can scavenge from my failed attempt at picking up a set of blowed up Hipermax IIs for cheap in hopes of having HKS USA rebuild them for me.
Only thing is, it's missing the sleeved nuts, which, lucky for me, Veilside180sx (is it Richard?) will provide those when I step up to the Koni setup that he sells, and on 1 of the camber plates, it's missing one of the 3 studs.
Now, I used one of the nuts that hold the plates to the strut tower to find a bolt that was the right length and thread/pitch from my spare nuts/bolts bin, and I've kept it on there for now, and would work if I had to use it like that, but I'm trying to find something that will work as a more "permanent" fix.
I looked at the other studs, from the top and the bottom, and they look like wheel studs.
Can anyone confirm that they are indeed wheel studs?
If so, I can pick one up, or I might already have one (I bought a set of the ARP studs for Camaros on my S13, it's still 4-lug, so I have 4 studs left over).
Thanks in advance guys.
