electric water pump ???
  • electric water pump ???
    im new to this forum and i did some searching and was unable to find out what is a good eletric water pump or should i stick with my stock one if any one is runing an eletric water pump tell your set up and hp im shooting for 500 in my sr22det heres what im running (90mm pistons 11:1CR stoct strock 810cc injectors BC264 cams GT2876R w/.86a/r 21psi boost custom ported head nismo thermostat 3row rad ) looking for input
    11.1:1 C/R & 21 PSI of Boost? What kidn fo Fuel are you running? Stock Water Pump is fine. Been used on many High HP apps. even ones that will make more then your GT2876R.
      Let's nip this in the bud right here, this is a more "grown up" forum, please use some proper spelling, sentence structure, etc. You'll get alot more help that way.
      To help with your quest, this guy is running a similar setup and has an electric water pump. There's some discussion starting on post #59.
        Sorry, a GT2876R won't make 500 HP. I run the same turbo. I only wish it'd make 500 HP... hah
        I'd personally stay away from an electric water pump. Just underdrive the stocker and you're good.
          I'm more excited to see what fuel he's running with 21psi and 11:1CR!
          C23, maybe?
            You built an 11:1 CR big bore motor? Sounds like a nice N/A setup with a VE head...but not what I would do for running big boost and trying to max out a bottom mount turbo. Instead I'd do 9:1 CR and run a top mount 3071R or 3076R, or a 2871R to make about 400 whp tops with pretty quick spool.
              Maybe he is running some water methanol mix.
                Anyone used an electric powersteering pump from an Opel astra?
                The buggy guys swear by them, we are keen to give it a go but were just out of time atm
                  Might be an idea if you lived somewhere else then N/A.
                  Correction, isn't saturn, or some GM a rebadged copy?
                    im running VP ms109 i emailed them whit my set up and thay say that it will be fine.
                    but is any one running eletric water pump???
                      I think the Saturn Aura or whatever it is was just a rebadged Astra.
                        Also the L series was based off the Vectra B, I miss my old S car
                          I have a Astra power steering pump. But I have not dared to install it as I'm afraid it will burn the generator. That sucker has a 80Amp fuse!
                            On that subject, is the SR alternator interchangeble with any nissan high output alternators. From trucks or SUV's?
                              You can throw on a Quest Alternator. Either the 110A or 125A. Cody makes the brackets IIRC.
