Every OE SR20RWD I have seen used those little restrictors inside the return line. Its common practice to take them out when going to a higher flow rate pump if you keep the OE FPR in place, and yes, when going to aftermarket FPR it serves no usage.
OE pump without that restrictor often shows a little fluctuation in fuel pressure every now and then, with it in its dead stable.
