So I've been poking around on the various forums about removing the speed limiter since I hit it at the end of the front straight at TWS in clean air.
This weekend I will likely be running quite a bit faster since we'll be running in a draft, and I'd like to remove the speed limiter before the event.
I've read over various threads similar to this: http://www.240sx.org/faq/articles/spdgov.htm and several of them mention the ECU goes into a safe mode of sorts...
I don't want to mess with adding switches and this and that- I just want the damn thing turned off.
Has anyone had any issues with this, or can recommend a different fix for the stock ECU? (and I don't have time or money to buy a new ECU... unless someone wants to overnight me an SE ECU without the limiter on their dime!)
Thoughts?
Thoughts?
