I went to a local autoX today and I was told I was lifting my rear tires during corner entry. What is the proper way of dealing with lifting my rear wheels. I get a little more oversteer than I'd like and my corner exit is not where I think it should be.
Attempts at helping the issue-
lower rear tire pressure
less rear rebound- 1/2 turn from soft Koni
slower entry speeds and different turn in
other options-
increase rear droop-How is the done?
remove rear sway bar (hicas)
change out 210K+ VLSD-Thinking about putting some heavier gear oil in it. Currently running OEM viscosity Mobil 1 gear oil.
more rear rebound-I thought this would not help with oversteer/corner exit.
larger front sway bar-Doesn't seem like it'd help the rear wheels from lifting
stiffer rear spring rates
stiffer front spring rates
44 front psi 37 rear psi (after 3-60sec runs)
450#front 350#rear springs
front struts full stiff/rear struts 1/2 turn from soft (Koni)
My full setup is in my STS blog.
other options-
