Just got a HICAS rack in the mail today.
First thing I noticed was the clear fluid dripping out from where the lines go. Definitely not ATF.
Then I check to see if it is a true HICAS rack. Without the inner tie rods I get maybe 3.3 turns from stop to stop. 2.8 turns with the inner rods attatched. Also has the 53F stamp that the early 90's models have so I'm guessing it is a true HICAS rack.
As I was checking the ratio I noticed there is a flat spot or a dip when the shaft is near centered. The shaft rolls fine until I hit that dip.... it gets kinda stuck there. As I press harder it rolls over this dip and continues to roll fine. It's almost like a tooth is missing or something.
When the shaft is sitting in this dip it has some play in it.... I can move it around slightly from side to side. It feels solid any other time.
Has anyone experienced this? Any ideas what would cause this? Would a rebuild solve this or is this rack done?
Also I have some ES bushings for the rack but the odd shaped one has about a 1/2" gap when I try wraping it around the rack.... is this normal or do I need different bushings?
Thanks
Thanks
