Hi all, i had a search around but couldnt find the answer
I am fitting (trying
) ES subframe bushes and am stuck, in the instructions it says leave the tabed coler in as it supports the bush which is fine for 2 of them, nice snug fit too
However for the other 2 (diff side) they have a full lenth coller with a lip on it, no tabs, the instructions make no referance to this, the fit is much tighter than the other, iv not tried to fully press the bush in incase i cant get it out again.
If i cut the coller out im worried it will be too lose and the botton stock washer will fit through the subframe when the car is jacked up
UK spec 200sx s14 kouki, Energy suspension bushes for 240sx
Do i cut the coller out or not?
Are your 240sx subframes the same?
Any advise appreciated
