I researched my options - considered ohlins, bilstein, kw, penske but at the end of the day, none had what i was looking for except Moton. I HATE upgrading parts and only want to buy good suspension once, so i bit the bullet and what showed up was heavenly. The quality of these absolutely exceeded expectation, and im blown away (im a very picky engineer, this doesnt happen often) suspension of this caliber is seriously next level
^^ a total thing of beauty. Moton double adjustables (15 independant bump and rebound settings, blowoff valve system for high speed bump control, huge main piston, remote reservoir compression adjusters mounted on swivel banjo fittings (makes mounting them easy!), and 2.25" spring hardware.
^^this is the top-secret R14 front suspension ive never shown anyone before. the Motons fit so perfect, its like the motons were just meant to be..
this is showing the drivers side remote reservoir compression adjuster
(pass side)
now to the rear --
installed (but waiting on the tender springs to arrive)
reservoir located, you can also see the fuel pump wiring
easy to see how the adjusters are mounted facing inwards, easy to access without removing the wheel
tire clearance at full droop
tire clearance at full bump
both reservoirs mounted, and the wing mount i am building now from 0.035 4130 cromoly
______________________
in other news:
NEW prototype BorgWarner Twinscroll Turbo - dubbed S300'P'
^^^look at the super badass turbine wheel geometry and my favorite feature of all, the vband compressor hsg to CHRA. soooo slick. I am looking to spool 1000rpm quicker and make 700+whp at 30psi boost... this should do it.
the legendary extended tip compressor wheel design, this is only 61mm inducer / 83mm exducer turbo, just like a GT35R but it moves 72lb/min at full-tilt, HUGE airflow for this small of a turbo (35R is 62lb/min for example). take a look at the far tip you can see the little "peak" that is mountain shaped on the top of each blade? thats the extended tip
getting ready for the charge pipe modification
4" downpipe flange welded on
^^old vs new... you can see how much smaller the new turbo really is
^^got the manifold and downpipe 2000degree HPC coated, and will use DEI heat wrap on top of the coating to further reduce engine bay temps
Front Aero
^^front splitter mounted on the car, you can also see the radiator ducting. coolers will be remounted and ducted next
^^strong enough for 330lbs @ 0mph, should handle 300+lbs downforce at 170mph!
Rear diffuser
to make a functional rear diffuser, it requires that there be an area with no obtrustions to block air from exiting under the chassis or from behind the tires. I started by cutting the quarter panels level with the frame rail, and then i cut out the spare tire well
^^cutting quarter panels level with the frame rail
^^removing spare tire well
^^20 ga steel plate fabricated, and mig tack'd in place.
^^welds cleaned up, spray painted grey
flat bottom rear is finished! now time to bolt up the diffuser when it gets back from powdercoat on monday :naughty
this bumper will be trimmed generously!
another shot of the rear, but this time the new spindles with proper toe rod geometry is installed
as she sits tonite, getting ready for a looong weekend!
now i have to corner weight the car, align it, and do a few tweaks from my friends from M-workz and motoIQ, then i can finish the aero, and turbo for one last update before the race.
(pass side)
now to the rear --
in other news:
Front Aero
Rear diffuser
