This questions is SCCA autocross related.
Weight vs. stiffness is the only meaningfull difference between the two that I know of, related to this subject. If there are others, feel free to discuss.
Neither car is going to be competitive with the 6-cylinder BMW's or the turbo-charged XR4Ti (boost is now unrestricted) in DSP.
My S13 coupe has the complete 5-lug S14 suspension (including rear subframe) under it but I'm severly limited in methods of stiffening the chassis. I previously welded in some fender braces from a convertible using the "update/backdate" rules but the rules have now changed and the section that stated "engines and transmissions must only be swapped as a unit" now also includes "unibodies", so even those little braces are now illegal. A cage would stiffen either chassis nicely but the additional weight is a killer. I will run a rollbar to make it legal for time trials. I've done most of what I can under the rules for the motor and measured 168rwhp and similar torque at the last dyno trip.
The next obvious class up is Street Modified. I can make up the horsepower difference there and there's a lot more freedom in suspension setup but chassis bracing is still quite restricted. Most all the parts I have laying around will fit either chassis so that's not a deal breaker.
The only disadvantage I've heard discussed on the S14 chassis is that it weighs more. The only advantage that I've heard discussed is that the chassis is significantly stiffer in stock form. I know Logr and Jim Bennett are running the S13 and Ace-in-Hole has done well with the S14 and there's a few more that have played in the class, although I don't know how many have done it seriously.
The cost of picking up an S14 chassis can be manageable if being a running car isn't a requirement. The cost of changing classes is going to be about the same on both.
Opinions?
Opinions?
