im getting my R14 ready for the modified tuner shootout <full build thread here: http://forums.nicoclub.com/zerothrea...tuner-shootout >
and im working on the rear susp. subframe bushes eliminated, so subframe moved up (and all inner pivots moved up). Im getting a set of Motons, and had to modify the aluminum uprights to accept the 1/2" heim
^^installed spherical courtesy of 2fast240us!!
^^rear upper shock mount
rear view (you can see why its still bumpsteering with my fubared outer toe rod location)
where have you guys relocated the outer tie rod point to? im considering 5mm below stock, but only want to change it once more! will cycle and record toe change with dial indicators and plot this weekend
