I built this splitter to maximum specs for Street Modified. The splitter extends 6" forward of a vertical line down from the front bumper. I installed to studs on the bottom side of the from frame rails to make the splitter able to slip on easy. Underneath on the crossmember are two more attachment points that pins go through to hold the back up. There are 5 heim jointed front support bars to aid in support.
The first version was made from cheap 3ply plywood as seen in the photos. The second version was made from 9ply 1/2" birch which is 100% more rigid. Also my second version has brake ducts in the front. The only pictures of it I have up right know are all of the GotBlueMilk photos at Laguna Seca.
Hopefully I can get some more photos up when I was making it and the attachment points.
Got Blue Milke Photos: http://www.pbase.com/autocrossracer/my_s13_240sx_hb
Front Spliter Version 1 Photos:
If anyone has any questions on how to build or is local in California I might build another one so let me know if you are interested.
