Does anybody else do anything about how much higher the engine is with Nismo mounts. It seems they are about 1/2" higher. I decided to do something about it. I cut the engine mounts(on the crossmember) to lower them 1/2 in and move the engine backwards 1" while I'm at it. I just started today but I have had it mocked up in there and all seems fine. I have a driveshaft shop aluminum ABS driveshaft and it had 1.5" play so I won't even have to shorten that.
I am curious how much weight it puts to the back but not curious enough to figure out a way to find out. It seems that these things are pretty heavy on the front crossmember so moving it even 1" will hopefully off-center it and put a disproportionate amount of weight to the rear. Don't know but it seems like a reasonable theory.
