Would the 1991 twin turbo one do the the job? or would i need to change something?
z32 subframe and uprights
what job are you speaking of?
IIRC, the z32 and s13 subframes are near identical. its not till the s14/r33 that they were changed.
also, the NA and turbo were also identical.
the uprights are the same as well IIRC. the rear hub bolts to the uprights, so the differnent size and spline count shouldnt matter as far as the upright.1992 LS13
385whp/370tq
then a z32 is not going to get you anywhere.
i believe there is a comparison picture of z32 and s14 subframes in the thread on the swap. you can see that they are different. I know from experience that the z32 is very close to the s13.
I found a s14 frame for 40.. Where are you located at?1992 LS13
385whp/370tq
Z32 rear subframe has the same high antisquat geometry the S13 has, and it's way wider than the S13 rear mounts. So it won't work.'18 Chevrolet Volt - Electric fun hatch for DD duty!
Z32 rear subframe is several inches wider than the S14 subframe. thus if the S14 frame fits on an S13, the Z32 definitely won't fit on an S13.Originally posted by SoSidewaysI don't care what color they are as long as they are LONG AND HARD.
not to mention TT uprights require TT axles... did someone mentioned that already?1995 Fouki S14 - re-energized ka-t project!
1999 F150 - gas guzzler parts getter
1989 Toyota Pickup - mandatory Pomona abandoned-in-driveway vehicle
2012 Mazda 3 Skyactive hatch - "The only 40mpg econobox worth driving"
