If you install an SR in an S13.
The SR came with the harness, puter and most needed components.
You do the wiring changes all right and check them 3 times.
It won't start.
The igniter gets hot and then quits working.
It might try to run a bit but won't start.
You check the wiring again but it is all right.
What is wrong?
Hadn't had this problem before.
Any guesses? If I just give you the answer, you won't remember.
It won't start.
What is wrong?
