I have AC on my S13 SR hatch.
I do track days with it.
I have a koyo radiator with dual elec fal fans.
My intercooler is right in front of my rad, moved the rad back 3 in.
I had heating issues at times.
First I cut out some fins from the condensor to allow more air through, helped a bit.
Next I put a bit smaller intercooler on, covered only half the rad, helped a bit more but didn't cure it.
Finally I added a smaller oil type cooler where the stock side mount intercooler was and plumbed the water from the turbo into it and then back into the outlet neck of the engine.
It cured the problem completely.
This is much easier if you removed the piping on the back of SR's and turned around the turbo water outlet to go into a fitting you welded onto the engine outlet neck when you installed your SR. I always cut off the pipe on the back of the engine right beside the other heater pipe and use 2 Napa hoses that fit perfectly. I have the numbers if anyone is interested.
I have seen so much stuff on fans and rad and overheating that I thought this might be interesting to someone. Hope it helps.
