any body have the part numbers for KAAZ LSD that fits the 1993 J30 differential with (this the one with 5 cults star like out put shaft )
3.9 ratio
thanks
S14 LS7
Rubicon X
G35 2doors Turbo
________________
The J30 diff (unless the '93 is speshul) has the same 6 bolt output shafts as the S13/s14.
Z32 diff has the 5-bolt flanges.
But IIRC, that doesn't matter because the flanges supposedly all have the same input spline. So if you buy the one that fits an R200 VLSD housing, then you should be fine no matter what flanges are on it.
The output shafts from the j30 will only fit in other vlsds, the open shafts are different. Therefore you need to order a kazz for a 240 that had a factory vlsd if you want to keep your output shafts.
