Just saw this, discuss.
Drop it like its hot (no)
Originally posted by Matt93SE View PostBuy shorter struts and save yourself the work?
I just thought I'd share my find this morning lol. That shouldn't be hard to make though... just to be accurately welded methinks."hexa-dodecahedron-triple-threaded-super-eleventy-way-adjustment-spec" dampers. -Def
it wouldn't even need to be that accurate. the rear shock doesn't determine any geometry like the front. and if you've gotten this far, you probably have length adjustable coilovers that can correct any slight variation in height from side to side.
The welding doesn't look very strong since I'm betting the weak link will be the bottom weld bead which is in shear and bending.
And it looks stupid.
McCoy, get rid of the 4x4 status and you'll get some more droop.'18 Chevrolet Volt - Electric fun hatch for DD duty!
http://www.ground-control-store.com/.../II=779/CA=232
what about using something like this?
That way, you don't have to chop up your shock towers.
*(I know they don't have a nissan application for this, but I've seen people cut out the center of stock upper mounts and weld an extension on them - which is fairly easily done.)1990 240sx - Aristo 2JZGTE, R154, GT37, Defsport Wilwood kit, KTS coilovers - daily driver
