Yeah so I'm kind of pissed when i read/research and find out there's something better than what i just spent money on... and u feel like wth.
I know a 240 is a 240 and not a ferrari/racecar/whatever, but hell thats why most of us get them on the cheap to make them something even better.
I decided to this time not cheap out as i did last time when i rebuilt the car... so now im thinking to myself ill only buy the most proven/regardless of price... so i was slowly getting all the spl arms...
I got everything for the front, and they just came out with beefier z33 inner tie rods
... but kuah told me they should be fine as they ran the same setup on their z32 and it worked, so im like okay.
But then i thought to myself i should switch to the s14 spindles to get some extra clearance maybe and widen the track?... but then would the SPL TC rods and tie rods work with that?... what about wheel bearings/hubs cause I already had new ones less than a year ago?
Then more importantly what pissed me off is the rear... i thought id buy all spl arms and solid subframe bushings, rebuild subframe... make it all tight and solid but then... i was reading the negative side of the s13 rear suspension (obvious as its more drift-happy than grip-happy).
Either way I have a hicas 17 year old subframe... rusted... with a hicas stopper and worn bushings... worn tie rods i suppose its definetely not stable and the previously installed whiteline subframe inserts snapped out...
So i already bought the spl traction rods and solid alum bushings... i was going to get the camber arms and ultimately lcas front and rear...
I was going to get a non-hicas subframe/sandblast/powdercoat... but its hard to find as most are rotten... so someone told me get an s15 one...
But then that makes me wonder... will the traction rods i bought work?... what parts will be interchangable?... and i can pretty much forget the subframe bushings as there will be need for offset ones... like wth
Argh... but i guess thats all part of the game...
I really want to spend money and make an ultimate mechanical grip setup here... not spend over and over again...
I want to get rid of the rear hicas subframe and get the s15 one... but then what is interchangable... can i still use the traction rods i bought?... where can i get the s15 subframe and how much...
