Some of you may have seen my post on Zilvia. Here's the short chronology:
1. Installed SR20DET with stock oil pan, 2003, no problems.
2. Switched to fake Greddy (ebay knockoff), again no problems. Never leaked or sweated oil despite many elitists' claims on Zilvia that the casting would be so porous you could see through it.
3. Read Dave Coleman's article about using a Tomei steel pan instead of a Greddy cast-aluminum pan because of the chance of cracking the aluminum. Had a panic attack. Bought a Tomei but COULD NOT get it to seal against the flange on the upper pan despite trying 4 times. Re-installed the Freddy, which of course went back to working great.
4. Fast forward to this summer. 240sxmotoring runs a special on the sheetmetal Moroso pan, so I figure I'll try it, having been nervous since the Tomei debacle. Bought one, and guess what? Same deal as the Tomei - it leaks, at least a tiny bit around a bolt-hole, no matter what I do.
Here's what I've tried in the last two weeks:
1. Installed with Red RTV. Leaked like a sieve.
2. Found out that Gray RTV really does work better than red for this - tried gray. Worked way better but leaked around two of the rear bolt-holes (by the crossmember).
3. Tried again after talking to my mechanic. He advised me to run two beads of RTV, around the inner and outer side of the flange, and to encircle each bolt hole. Did this. Still leaked around a rear bolt-hole.
4. Found a shop to cut me a custom gasket from hi-temp silicone. This was this past week. Installed it Thursday night with a very thin bead of RTV on either side, encircling the bolt-holes, to glue it all together. Still leaks around the center rear bolt-hole.
The car is currently draining again, for another removal-and-flange-cleaning session. I sold the )(!$(#%%*^ knockoff, or I'd stick it back on the car and be done with it.
Questions/conclusions:
1. The stock pan and the Freddy pan have a groove around the flange, presumably to help hold the RTV where it belongs. These pans did not leak. The Tomei and Moroso have no such groove. Does anyone think this matters?
2. It's possible the Moroso has a high spot by these bolt-holes that keep leaking but I would have figured the gasket would deal with that. I don't believe there's anything wrong with the pan, I'm just grasping at straws.
3. Several people have suggested I try the copper RTV but I can't see how that would improve the situation. Thoughts?
I'm ready to commit murder over this. My inclination is to buy an ISIS or similar knockoff again and sell the Moroso; I don't want to go back to stock because I don't want to give up the extra volume or the port for my oil temp sender.
I'm sorry for writing a novel, but I'd be grateful for any input. I'm going to remove the Moroso pan right now and the car will be down until I can decide what to do.
