I've got a dilemma.
Currently I'm running the following monitors:
1. Mechanical boost (analog).
2. Electronic boost - the readout on my Greddy EBC.
3. Oil pressure (analog)
4. Water temp - Pivot fan controller
5. Oil temp - Pivot fan controller
Here's the issue: the oil temp sender for my Pivot readout has failed, and I've thus far been unable to find a replacement. While my car is really a street car, I'd still like to be able to monitor the oil temp. Right now I have the boost controller and fan controller next to the radio, while the boost and oil pressure gauges are on the A-pillar.
I could do away with the fan controller (switch to a DiF unit or similar), use my PowerFC commander to monitor water temp, and get an oil temp gauge, but this creates a new problem, namely gauge placement. I've had the gauges in the center stack above the radio, I've had them in the center vent only to find that I really don't want to live without the center vent, and now on the A-pillar. I'd love to relocate the climate controls and put gauges there but I wouldn't know how to do it or where to put them.
So, I'm looking for some brainstorming. I'm hoping to locate a temp sender and make this whole discussion moot, but if I can't I'm going to need to come up with a solution. My best idea is to get an oil temp gauge and a DiF fan controller, ditch the pivot, put the oil temp and oil pressure on the A-pillar, use the Commander for water temp and the boost controller for boost, but I don't much like the Greddy EBC readout. This would mean a lot of re-arranging and expense too.
Any suggestions welcome.
