I have two issues, both very minor.
First is a "clunk" i hear when I press on the brakes sometimes. I've had it since I owned the car. The bushings on the tension rods were shot since day one. I replaced those with oem tension arms with poly bushings. The thunk was still there even with the poly bushings. I figured it was my install (I literally bolt it back together with my air gun). I've basically replaced everything in the front now, and I still get this clunk every now and then.
Tips on better analyzing the problem?
Secondly. I have binding in the front. I hear this metal sound when I turn my wheel. I'm guessing it could be my outer tie rod setup? I also think it could be my sway bar endlinks binding.
What is the best way to look for binding and adjusting it? When I did the corner balancing they checked for pre load on my sway bar end links. There wasn't any.
Just small annoyances I'd like to find and fix.
