I'm curious what other S-chassis owners are running in terms of ride height with whatever coilovers you're using. I'm most interested in S13 drivers. I'm trying to strike a balance between a low center of gravity and rubbing in the front fenders, and I'm trying to figure out if one end or the other of the car should be higher - e.g., on a B13 the rear wheel arches are shorter than the front, so the measurements would be different if the car were level.
I'm still fooling with my S13, trying to finalize some things before taking the car for an alignment, and I'm working from a position of some ignorance.
If you have the time and don't mind, please post your height at each corner, measured straight up the center of each wheel.
