Will an air bubble or pocket surrounding an aftermarket temp sender cause higher than actual water temp readings?
Temp issues. Possible overheating.
No, but air bubbles going through the motor will cause water temps to spike up since you have no coolant taking the heat away for a second.
Air in the system will cause it to just plain run hotter though, as you have parts of the engine not actually cooled by coolant.'18 Chevrolet Volt - Electric fun hatch for DD duty!
Thanks Def. That wasn't what I wanted to hear at least my understanding of your explanation. Heres my issue: My Omori gauge reads much higher than the PFC commander which gets its reading from the factory temp sender and controls the operation of the electric fans. But, my Omori gauge is usually what I use to keep an eye on temps as I rarely use the Commander. Today all of sudden the Omori gauge reads real hot but the fans haven't kicked on because the PFC was reading temps well below. I'm thinking I wasn't actually running hot (cool day and easy driving) but maybe my sensor went bad? or, I was hoping, it's exposed to air bubbles or an air pocket.Jim Schumacher
My 240
Guess the Omori gauge is in the upper radiator hose? It'll naturally read a bit hotter than the factory temp sensor.
What were the temps in question?'18 Chevrolet Volt - Electric fun hatch for DD duty!
Originally posted by Def View PostGuess the Omori gauge is in the upper radiator hose? It'll naturally read a bit hotter than the factory temp sensor.
I'd let the car run until the Commander temp reading kicked on the fans but am reluctant to do so because the Omori unit would probably be reading upwards of 270 degrees and I got nervous not knowing the real culprit.Jim Schumacher
My 240
Hmmm... does coolant come out when you open the bleeder screw/bolt? Is it filled up to the top of the radiator?'18 Chevrolet Volt - Electric fun hatch for DD duty!
Jim, for what it's worth, my Pivot fan controller always reads 5-7 degrees C higher than my PowerFC commander, and they BOTH read from the factory water temp sender. Not sure what that translates to in Fahrenheit but I know it's a significant difference.
I would check the coolant level, but I suspect the sender for your Omori may have a problem, and isn't reading correctly.1990 S13, SR-swapped "Budget Baller" - gone down the road...
I doubt this is happening, but when the temp sensor was on its way out in my truck, it caused the thing to read lower than actual temp.
The symptom for that in my case was the truck running rich, since it was an old TBI setup.. As it thought the engine was colder, it ran richer and richer. then the sensor failed, the truck wouldn't run anymore. soon as you crank the engine, it would run the injectors wide open and flood the engine. DOH!!
Anyway I doubt that's the case here. as has been suggested, you might try to bleed/burp the system and see if you can get any air out of it, then keep an eye on the temps.
and yes, you'll also have quite a temp difference between what's going into and what's coming out of the engine- especially on colder days where the radiator is more effective.
When I say that.. where does the factory temp sender read? Is it on the cold coolant side coming directly from the radiator?
have you always noticed a large temp difference between the two gauges, or just not paid that close attention before. (my autometer gauge and my OBD-II reader show within about 5 deg of each other. autometer gauge is plugged into the factory dash gauge sender spot, right next to ECU temp sender).
One more thing.. disconnect the senders for both and clean the connections. apply some dielectric grease when you put it back together and see if that causes a difference in the readings. it's possible that the connector is simply dirty.
just throwing out ideas here, if you can't tell. maybe oneof them will help ya.Originally posted by SoSidewaysI don't care what color they are as long as they are LONG AND HARD.
Originally posted by Def View PostHmmm... does coolant come out when you open the bleeder screw/bolt? Is it filled up to the top of the radiator?Jim Schumacher
My 240
Originally posted by Rittmeister View PostJim, for what it's worth, my Pivot fan controller always reads 5-7 degrees C higher than my PowerFC commander, and they BOTH read from the factory water temp sender. Not sure what that translates to in Fahrenheit but I know it's a significant difference.
I would check the coolant level, but I suspect the sender for your Omori may have a problem, and isn't reading correctly.Jim Schumacher
My 240
Originally posted by Matt93SE View Posthave you always noticed a large temp difference between the two gauges, or just not paid that close attention before.Jim Schumacher
My 240
One thing mentioned in the FSM for the maxima is that you have to jack the front end of the car about 3' in the air to get all the air out of the system. there's high spots in the block and coolant lines and crap like that that will retain air unless you jack the car up.
(or worse yet- the newer maximas require use of a vacuum pump attached to the system to suck coolant into all the little passages!)
also remember to turn your heater on while you're doing it. there's high spots where air can gather in the heater hoses and in the core.Originally posted by SoSidewaysI don't care what color they are as long as they are LONG AND HARD.
Originally posted by shoes59 View PostI never really paid attention but suspected the readings were close because the fans would kick on when the Ormori gauge read about 210 which is the temp the fans are supposed to kick on, right?Originally posted by SoSidewaysI don't care what color they are as long as they are LONG AND HARD.
Originally posted by Your Mom View Postread from my aem from factory i see a 10 degrees difference from factory sensor to the defi sensor that's mounted in the output port.Jim Schumacher
My 240
