ID this subframe/diff
The link provided says it is a "JDM Nissan 38311-43M10 VLSD Differnetial w/ Speed Sensor and plug"
It looks identical to a S14 diff and crossmember. The rear diff cover is the same for VLSD and open diffs so you have to look for the orange LSD sticker on the outside or have a picture of the inside to visually confirm.
Viscous LSD's are nearly worthless (especially 100,000 mile used ones) for any performance use as they are designed to keep grandma from spinning out or complaining about noise while driving on the street. Replacement viscous couplings from Nissan cost over $1000 so they are not designed to be services but I have heard of people tinkering with them and modifying lockup using different fluids.
The 5 lug hubs fit on S13 uprights and work with S13 axles without any issues.
If all you need from this is the hubs you might be better off buying the hubs separately and then buying a HLSD with the matching input shafts to install in your S13 diff instead of purchasing and shipping an entire subframe just to get a 5 lug conversion.
If your rear wheel bearings are good I believe you can just buy the 5 Lug hub from Nissan and press it in.
PN# 43202 - $140 eachLast edited by Umai Kakudo; 05-13-2009, 10:53 AM.The Nerd shall inherit the podium for knowledge is power.
That is 100% not an S15 subframe. There are a few brackets that are different, plus the S15 runs beefier rear subframe bushings.
That sensor on the snout is for ABS. I'm pretty sure that the S15 uses the same sensor for both ABS and VSS.She's built like a Steakhouse, but she handles like a Bistro.
That is for sure an s-14 rear subframe/diff. The s-15 diffs have the speed sensors mounted to the diff cover and the tone rings are on the output shafts. Since that one only has a single speed sensor in the nose of the diff it is not an s-15 diff. I payed $50 for my complete s-14 subframe with diff and axles (open diff), but w/o brakes and hubs.function > form
Originally posted by racepar1 View PostThat is for sure an s-14 rear subframe/diff. The s-15 diffs have the speed sensors mounted to the diff cover and the tone rings are on the output shafts. Since that one only has a single speed sensor in the nose of the diff it is not an s-15 diff. I payed $50 for my complete s-14 subframe with diff and axles (open diff), but w/o brakes and hubs.She's built like a Steakhouse, but she handles like a Bistro.
Originally posted by Epstein View PostNone of my S15 HLSD diff setups have ever had the sensor rings on the output shafts.
Regardless of whether all s-15's have those sensors, the ears should be on the cover if it is truly an s-15 subframe.function > form
OK, just for completeness:
The Trust/Greddy cover has them because the part is universal for all R200's which use that 2-stud rear mounting arrangement. Z32, S14, Q45, a-dozen-jdm-cars-we-didn't-get, R33, R34.
The output shaft mounted sensors are for 4-channel ABS. The S15 (Spec-S or Spec-R) does not have 4-channel ABS. I also just confirmed in the S15 FSM that the snout sensor is used for ABS, and the speedo is fed it's speed signal from the ABS computer.
It was common for Nissan to put ears on diffs that would never see use. The S15 diff did come with ears, but without sensors or sensor rings.
The sensor ring is a separate part, and meant to be pressed onto the output shaft. That is, if the output shaft is stepped and smooth on the inner portion to accept the ring.
I'll post pics this weekend that I took comparing my S14 and S15 subframes. I should also have them measured out as well.She's built like a Steakhouse, but she handles like a Bistro.
The moral of the story is if the cover does not have the ears on it, it is not an s-15 diff cover. Therefore that is not an s-15 subframe.
/threadfunction > form
Originally posted by racepar1 View PostThe moral of the story is if the cover does not have the ears on it, it is not an s-15 diff cover. Therefore that is not an s-15 subframe.
/thread
That's why my last post was so long.She's built like a Steakhouse, but she handles like a Bistro.
Originally posted by charles View PostThanks for the info guys, I guess the search continues for a real deal S15 HLSD.... seems to be only moderately easier to find one than the infamous HICAS steering rack
could still get it.
I saw one come up on fa, and i jumped on it.
